Fuel injector impedence
jon1971
can anyone tell me if you can run low impedence injectors on an rb25det with a top fed fuel rail? If so how do you go about it?
Thanks guys!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Buy a GTR restor pack and wire it in, or get 2 DSM restor packs and wire up your 6 high impeadence injectors.
jon1971
So if I use the GTR pack I can use low impedance injectors.
I must not be understanding you when you say that I can get 2 DSM packs and wire up my high impedance injectors? The rb already runs high impedance injectors right? Sorry I'm just trying to get this all sorted out!
I have about 4 or 5 DSM packs lying around.
Thanks again!
gawdzilla
Car: none
you need 2 packs cuz each dsm resistor pack will only have resistors for 4 injectors. unless you're using one from a 3000gt or something... not sure if they have the pack or not.
rb20 and 25 use high impedance injectors. rb26 uses low impedance. all ecus expect to see high impedance, so you need to run resistor packs with the low impedance.
jon1971
So when Yellow4G63 said "or get 2 DSM restor packs and wire up your 6 high impeadence injectors." What he ment to say was "or get 2 DSM restor packs and wire up your 6 LOW impeadence injectors.". Is this correct? I'm trying to make 100% sure this is correct before I go wiring every thing up! I don't want to burn my injector drivers in my ecu up!
Thanks again!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
You're right, that's what he meant to say.
Yellow4g63
Yeah what he said. Cause the DSM is a inline 4. You would need two for a inline 6.
jon1971
I've got a resistor out of a 1991 Acura Legend V6 and was wondering if this would also work? I would rather use this 1 instead of using 2 dsm resistors.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
(off topic) ive got the same exaust manifold that you have in your pic and just FYI...that last runner will most def have to be modified to make any type of downpipe fit
