FUEL INJECTOR HELP
dbentley1989
Car: nissan 240sx
Hi I just replaced one of my fuel injectors about 3 months ago, it was running fine then it starts the same stuff, so I check the fuel injectors agian. The same one I replaced went out again, Is something causing this to happen or is it just a bad injector, please help I dont know why the same one would go out again.
ZiG
Car: 1993 240sx coupe
You don't actually think you're going to get a response when you are that vague, do you? Try giving a little bet more detail.
dbentley1989
Car: nissan 240sx
Well first the car was Idling rough and was tacking off slow, so I checked the fuel injectors by pulling the electrical connections, The last one closest to the fire was was out, So I bought a new injector. That was the problem, I ran great for about 2-3 months and starts the same stuff as before, So i figured another fuel injector. I check all of them and its the same one closest to the fire wall. The one I just replaced. No my question is is there something causing this one to go out or was it just a falty injector. what can I check. Sorry for being so vaque.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Check the ignition to that cylinder; it might be going out intermittently.
