Basically did placing fuel injector cleaner in the vacuum hose create damage i.e. stalling , shut off, eratic idle etc. And in the process were the tps sensor or cam shaft sensor affected as the computer said. It was a small scale comp. and the mechanic said the biggger computer which was being repaired is more accurate.elwesso wrote:Ive gotten all sorts of crazy codes occasionally when checking codes....... Make sure the connector is tightly fastened to the ECU..... If its not too much trouble, I would leave the ECU out for a while so you can easily check them........
Other than that, Im nto really understanding what your asking.....!
Ran it 10 minutes to let all the smoke out. This was their "technique". It would have made more sense to me to put in the fuel line over the vacuum hose.I thought I could burn it off by driving hard. Now I have a black-white smoke intermittently which means I'm probably running rich. Or maybe my injectors were so dirty it killed one of my injectors?! Gonna have to put it on the computer at Infiniti.DAEDALUS wrote:I've done that with SeaFoam. Never poured inject-r-kleen through the intake though. But when I did the seafoam it smoked pretty bad for maybe 5-10 minutes. Have to be careful to not pour so much in that it hydrolocks the engine. How long have you run the car after the treatment?
Glad you said that Heath. I talked to a mecahnic outside Infiniti who stated the same thing. The vacuum leads to the intake chamber so it is impossible. If any thing the fuel line return line should have been used. Either way Infiniti cant see me til the 14th. I hate NY! I tried revving like a maniac up and down the highway but it must not have been enough.Q451990 wrote:The injector cleaner in the vacuum line isn't cleaning the injectors (not possible) - they were probably trying to clean intake deposits from the valves and plenum. My guess is that they loosened up enough stuff to cause fouling on the plugs. Any of these cleanings should be followed by a blow-the-doors-off high RPM drive to keep the deposits from lodging in the lower intake/valves, etc - instead you want to burn them and send them out of the exhaust.
Heath
Damn! Redliners huh? I never used Seafoam before. Has anybody tried placing that in your vacuum hose? In NYC it's hard to keep your bumpers and not get dings. It's pretty cool though. It's posted in rides. Hopefully. Thanks wes.elwesso wrote:Do about 10 redliners (1-2 shift, and a 2-3 shift) and let us know if anything comes out, or gets better.......
You should have redlined it IMMEDIATELY after application of seafoam......
And they are right, there isnt any way seafoam and its effects would clog injectors...... Air comes in one valve, and the injector is over another valve.......
We do have the same color, but I bet yours looks nicer (i have some scratches)......
My fault, let me be clearer. They took off the vacuum hose (brake booster line)and put some fuel injection cleaner in there. I had a smell in the car that resembled burning deposits. However, scrap that I owe you a six pack. I dont know why I didn't redline earlier. I started in first-second to third and what a difference. 1st gear alone shot out a long trail of white smoke. I did this a few times. The car no longer shuts off at idle or after a full stop. I wasn't getting the full results but not dropping the gears. Still I need to check it on the computer because my check engine light has been coming on intermittenly. Don't know what the hell that is about. I noticed this for a brief second right before this incident so we'll have to see. Maybe plugs are fouled up from that air meter problem I had this summer. Good looking Wes.elwesso wrote:BTW..... How did you get it in there if you didnt put it in the vacuum line (brake booster line being the easiest)
I know, I know. They did this before I knew what was going on. Infiniti seemed to co-sign this too. It's started to stall and cut off when I stop and I smeel the burning desposits in the cabin sometimes. It's going to Infiniti today to go on the computer. I could get a computer reading cheaper than the dealer but I figure in this case it's safer to go with the real deal.elwesso wrote:YOU used fuel injector cleaner through the intake?? You should only use the product the way its designed...... They probably have different formulations to get rid of carbon, rather than to get rid of injector deposits.......
Just keep the RPMs up....... Gas mileage will suffer, but whats a few extra 5mpg in an already bad Q.....?
My guess on the check engine light is gonna say injector leak, which means it reads that its running too right, which leads me to believe some of the deposits havent quite gotten out.......
LONG LIVE THE BURGUNDY BERRY Qs!!!
I wish I could too. I have the stats from Infiniti whatever they mean.DTC RESULTS TIMEKNOCK SENSOR 0INJECTOR LEAKS 25elwesso wrote:a supercharger!!!!!
I think he's referring to the IAC.......
Man OLU, i wish you could come down for the oct 18 indy meet.......!
So its still cutting out on you somewhat.......? If you have an intermittant CEL, and its the MAF, the engine shouldnt go above 2000 RPM.....
