Fuel Injector Cleaning Service
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
DeatschWerks
Hello all!
DeatschWerks is here to offer High Performance, Drop-In Fitment, Aftermarket Fuel Injectors for your cars.
They are PnP, and that means: No Splicing, Cutting or Mangling of your Harnesses! Just drop them in and go play (after some tuning, of course).
We currently offer Products for much of the Nissan '90s and late model performance line up, with some crossover to the passenger cars, as well.
We also offer Injector Servicing.
***FOR ALL NICOCLUB USERS, SPECIAL FORUM UPGRADE TO OUR FORUM DYNAMIC SERVICE FOR THE PRICE OF OUR BASIC SERVICE, AND FREE SHIPPING!!!!***
****Make sure you write at the top of the service form that you are a member of NicoClub.com!!!****
DeatschWerks Injector Services
Available on any gasoline fuel injector...OEM, Aftermarket, Sidefeed, and Topfeed.
We have taken what we have learned from building precision high flow injectors and applied these same principles to develop the ultimate injector cleaning and flow testing system. THREE levels of service are available to suit your needs, but each service receives the same quality and attention to detail that we put into our own highflow injectors. Also, all injector services are performed on the same precision calibrated equipment that we use on our own injectors...so you know the results you get are dead on.
Ordering
Ordering injector services through DeatschWerks is quick and easy. Simply choose the injector service you want (see descriptions below). Print out and complete the PDF order form available on our website: DeatschWerks Injector Service Order Form. Then, package your injectors with the order form and send it to the address at the bottom of the form. Be sure to package your injectors in plastic to ensure no residual fuel is leaked during shipping! Feel free to contact me if you have any questions or need help with which service to choose.
Basic Service - $19/Injector
Looking for better gas mileage, smoother operation, and crisper acceleration?
Installing used injectors and want to be sure they are clean and operating properly?
Then the Basic Service is for you!
PROCESS BENEFIT
3-step Ultrasonic Cleaning
Optimum Atomization and Flow
Replace O-rings, Filters, and Seals
Ensure Leak Free Operation
Check Coil
Discover Coil Problems
Leak Test @ 100psi
Find Leaks at Pintle
RPM Ramp Test - Exclusive DeatschWerks test!
Pulse-Width Ramp Test - Exclusive DeatschWerks test!
Spray Pattern Analysis
Verify Proper Atomization
Static Flow Test
Check Balance of Flow Rates
ID Etching, links each injector to results on report
Lubricate and Bag, preserves optimum working condition
System Calculations, min/max/avg flow and system balance
Basic Report (1 page)
Forum Special Dynamic Service - $19/Injector and FREE SHIPPING back to you!
The BEST deal in town!
PROCESS BENEFIT
the Forum Special includes everything in the Basic Service plus ...
Everything in the Dynamic Service minus the pre-test!
Dynamic Service - $29/Injector
Having an engine problem and suspect the fuel injectors?
Tuning your car for more boost and want to yield the higher and safer whp?
Then the Dynamic Service is for you!
PROCESS BENEFIT
the Dynamic Service includes everything in the Basic Service plus ...
Flow-Rate Pretest, for before and after comparison
Dynamic Flow Testing, simulates real driving conditions
Fuel Pressure Calculations, valuable tool for FMU/AFPR users
Performance Calculations, defines limits of fuel system
Dynamic Report (2 page)
Dynamic PLUS Service - $39/Injector
Are you the picky type who demands only the best for their car?
Are you a tuning your car for maximum power and efficiency?
Then the Dynamic PLUS Service is for you!
PROCESS BENEFIT
the Dynamic PLUS Service includes everything in the Basic AND Dynamic Service plus ...
Customer Defined Testing Parameters, you can choose testing pressure, duty cycles, rpms, etc. to build a complete custom test
Advanced Coil Testing, loaded/unloaded and at various operating temps
True Balancing and Blue Printing, bring atomization and flow to within 3%
Lag Measurement, valuable tuning tool (upon request)
10-point Dynamic Test, maps injectors through all duty cycles
Linearity Testing, graphs injector flow during entre range of duty cycles
Dynamic PLUS Report (3 pages)
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
is this deal still good? I'm about to send you some injectors for my 91 Maxima.
Thanks!
DeatschWerks
Guys this is an on-going special.
As we are NicoClub sponsors, this special will always be available to you Nico Members!
donald
2010 Pathfinder LE
Cool... because I just shipped out my injectors to you guys :)
should arrive Friday, so I'm told
Thanks!!!!
Return to “Advertisers' Marketplace!”
