fuel injector cleaner **do not use**
yashin
Car: football, rugby
not sure if its been posted before, but i thought id put this uptake a look
i use to use this stuff until i saw this
http://www.imagestation.com/my...issan
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
It mentions the truck KA24E but not the 240sx wth? It lists the damn VG30E like 3 trimes.
fiznat
Car: Grown up :(
hm how come it only says 91 KA24DE? I assume this will apply to all KA24DEs then?
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
ITS ALL BULL, FULL INJECTOR CLEANER IS JUST A MIXTURE OF ALCOHOLS TO STRIP GRIMED GAS FROM THE FUEL SYSTEM. THEY POST THAT CRAP SO WHEN A FUEL INJECTOR FOULS YOU ARE FORCED SO TO SPEAK TO BUY NEW ONES. I HAVE USED FIC ON FOUR OR FIVE SEPERATE OCCATIONS IN THREE DIFFERENT ENGINES WITH OUT A PROBLEM.
89 AND 90 240SX KA24EQUEST 00 VG30E90 PATHFINDER VG30E
The 94+ Q45 has pintle-less injectors...
I have mixed feelings on this one - Let's get Dennis' (Q45tech's) opinion on this one.
BuudWeizErr
What the hell is a pintle?
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
:eek: talk about freaking people out.
if that was such a huge issue with KA's and other nissans it would be common knowledge on the boards by now-- wouldn't it?
i used seafoam, and b12-chemtool on my car on occasion.
lessthanjakejohn
i don't see the big deal?
BuudWeizErr wrote:What the hell is a pintle?
I'm gonna pretend I didn't hear you ask that Ryan. :D
MrFox
Interesting.
From a search on Google:
Quote »Ron wrote:
>I agree. Unless you have a reason to use injector cleaner or fuel tank>de-icers (alcohol), you shouldn't use it as regular as the cleaner>companies recommend. In the early 90's Nissan switched to bottom>feed-pintleless injector . Bottom feed means the gasoline>(with any additives) cools the injector windings which are sitting in the>gasoline. Constant injector cleaner can take the insulation off thewindings>and cause the injector to fail.. Pintleless means there is no pintle thatcan>get dirty.
There may be more reasons then this but I am not sure what. On another listsomeone had mentioned a SAE paper on fuel system cleaners and that oneshould avoid giving your car a steady diet of these additives. I shouldhave asked for the details. This was a list for cars that use the old topfeed injectors.
Carl Haines[/quote]
rydwhite
Car: 2003 Infiniti G35 Coupe
I've read somewhere, can't remember where, but I will try to find the article, that these products cause severe harm to your cars fuel system and should never be used. This post reiforces what I have already heard in the past.
yashin
yeah i wasn't too sure about this either, but i figure that nissan is just tring to help us out
if we could get someone to verify this it would be great
for now, im stickin wit , better safe than sorry
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
It's something with the Nissan rubber on the injector seal that doesn’t like cleaners…
MasterMan
Car: nothing running at the moment city buses "uck here
i was told that sea foam was the only kind that should be used... i have used it quite a few times in my gas, and oil.. hasnt done anything bad yet.. it does make my engine run better.. atleast seems like it idles better after i use it..
prigo
Actually, Fuel Injector cleaner to begin with is mostly BS, for something to truely clean your injectors EFFICIENTLY it would have to be near-corrosive.
Not entirely true.
BG products have been used and recommended for YEARS by top Infiniti mechanics. BG44K is basically the same chemical solvent that constitutes "Techron" (the Chevron gas additive). However, in the gas, it's so diluted it's only useful to PREVENT further buildup. The BG44K is highly concentrated and does a GREAT job of cleaning injectors... However, no product will reverse 100K miles of buildup - They need to be removed and cleaned OFF the car.
Mayhem_J30
Car: Ummm...My Car
Richard A Parr wrote:AZhitman, would you care to elaborate on the correct methodof cleaning injectors OFF the car:help That would be of considerable benefit to the readers of these boards. Thanks.
rail flush and/or rebuild
Mikie
Car: Cars/Music/Bands/Women/Carousing/hunting/offfroading/fishing/racing/strippers
so, since have a CA does anyone know what the best or some of the best products are, and how frequently should they be used for the best results - and most longevity from the injectors?
APEXi240
Car: 08 Nissan Versa S hatch
It's like a minature pint of beer. Somewhere between 12oz and 16.
szh
Car: 2018 Tesla Model 3.
Here is a photograph (courtesy of Dennis aka Q45Tech) that will explain pintle and pintle-less injectors:
http://www.sdsefi.com/injectors.htm
Z
szh
And here is an older thread that covers the topic of BG44K and pintle-less injectors:
http://www.nissaninfiniticlub....26489
Z
szh
AZhitman wrote:The 94+ Q45 has pintle-less injectors...
Hi, AZHitman.
Dennis has commented on this before ... see the link to the thread I just posted above. Infiniti also has a similar TSB to the Nissan one in the start of this thread.
Z
szh
APEXi240 wrote:It's like a minature pint of beer. Somewhere between 12oz and 16.
ROFL !!!
Z
Mr. Parr - FYI, BG44K is NOT available to the general public. It is only sold to authorized mechanics, as it is a highly concentrated formula (not your watered-down STP crap you buy at PepBoys).
If it's good enough for Infiniti Master Techs (and Dennis) and the guys at T3, it's good enough for my baby.
