racerken »
https://forums.nicoclub.com/racerken-u144820.html
Mon May 19, 2014 6:10 am
I've got this dilemna...
I'm doing my 120k maintenance so I'm taking care of belt, tensioner, chain tensioner, water pump, fan clutch, thermostat, hoses, Plugs, and conducting the Power Valve Actuator/VIAS epoxy fix to kill the 2200 rpm buzz. So while I have the intake collector off, I thought I may as well take care of the fuel injector cleaning and O2 sensor replacement. Am I nuts?
The idle is smooth but I wonder when the fuel injectors get gummed. (should I just wait till things get rough?)
I'm more concerned about the fuel injector because it would take 1.5 hours to remove all the stuff just to get to the injectors.
The up-stream O2 sensor reads .2 off of normal so one bank is getting rich gas I guess. (again, should I even worry?)
Not so concerned because I can always reach these guys from the wheel well.
And btw, rock auto carries many brands of O2 sensors with prices doubling! Which one is recommended? Bosch, Denso, NTK?
I'm trying to get the new car performance for the last leg of this car.
120k miles.
Michigan driving with start-up and shutdown within 5 minutes in freezing weather x 5 miles per trip x 9 years.
I'd appreciate any comments.
Thanks,
Ken
