Stop replacing them with phase 1 injectors. They are guaranteed to fail with the ethanol they put in basically all gas now. You don't need to go with another brand, you need to get Phase 2 Nissan/Nismo. You need to replace all 6 and get an adapter kit to do this (
http://conceptzperformance.com/Cart/des ... .164.64.90). Or...you can keep replacing them, and I can almost guarantee that if you've seen one fail in under 10k miles you're putting all ethanol gas in your car now, which means the others will fail in short order. I went from 1 bad phase 1 injector to 3 over a short period of time.
Also, if you want to be stubborn and go with another brand, do LOTS of reading. IMO it's really not worth it for the gamble you take with remanufactured and re-drilled stuff that's out there.
http://z32.wikispaces.com/Fuel+Injector
