Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Thu Jul 26, 2007 4:40 am
Backing up a bit to a month ago, did your car just die one day or what started the event of it not running?If you can hear the injectors click, and you have checked with a gauge that you have fuel pressure, the injection process should be happening.When you crank he engine over and it doesn't start, can you smell raw fuel at the tail pipe? That should tell you if there is fuel being injected, and then it's likely a spark issue.It sounds to me like you might have an electrical issue in the harness or a bad relay.I would caution against using starting fluid as it dries out the cylinder walls very rapidly and can damage your engine.
