Fuel Injection problem
Ray
Car: RC modeling
I have a problem with a ka24de engine, all my fuel injectors are firing at the same time which fluids the engine and will not start.
NISTECH
start by checking your coolant temp sensor connector for corrosion then check your base idle setting
U12 2NR
late reply to this but....
Upon startup all the injectors are supposed to fire at once. If they're flooding the engine then you should check your fuel pressure.
