KoopaTroopa »
https://forums.nicoclub.com/koopatroopa-u128221.html
Fri Jul 13, 2012 6:24 am
Installed a walbro pump in the 240 this week, got a megan racing (probably my problem right there) fpr. Installed everything and noticed the pressure bouncing in a consistent pattern between 20 and 50 psi. Put a better secured and shorter vacuum line on thinking maybe the one i had on there currently was leaking. Voila, car smooths out steady 30 or so psi, great. Shut off the car and go to bed. I go to start the car this morning and its running shotty as ever, fuel pump sounds like its spitting air bubbles. Pressure reads around 70psi (didnt adjust the pressure from before so i have no idea), i pull off the vac line and get sprayed in the face with fuel.
Bad fpr?
