Fuel hose Q45 G50
burijon
Car: Went to the darkside...acurazine
This has been posted before but can't seem to find the exact details again. What is the type of fuel hose that I need when doing the plenum rehabilitation? This is the stuff you buy by the foot. How many feet do I need of it?
Thank you NICO!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Best deal is the Nissan part number, but you end up with about 8 ft.
Joe sells it by the foot at $13/ft. The whole shebang only costs $39.
ponzy
Car: infiniti q45
fuel injection hose.......you can have it in your local shop.....goodyear($2/yard), gates($4/yard), as long as it's thicker from the outside diameter but same inside dameter, it's all good.
note: edit: /yard
Modified by ponzy at 9:39 PM 4/10/2007
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Actually, it's all either Metric or SAE.
Get the OEM metric from Joe.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
IMO OEM fuel hose is kind of a waste... $40 for 3 feet of fuel hose??? Whatever you gotta do but so far 300psi fuel injection hose has been treating me real good, after a few years...
Id be surprised if even T3 used OEM bulk fuel hose..
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:IMO OEM fuel hose is kind of a waste... $40 for 3 feet of fuel hose???
Nope, $40 for 2.5m.
And it is sized correctly, unlike SAE hose. Hence, it won't leak around fittings under the plenum on cold mornings as soon.
Q45tech
Unfortunately even old oem hose cannot live with ethanol for an extended period.
Modern advanced hoses have a fluoropolymer [teflon] interliner.
http://www2.dupont.com/Automot....htmlh ... ot....html
http://www.dupontelastomers.co...rrierThe point is should you be using oem or something better and more expensive that will last and not break down internally?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
If it's not available commercially, and if the VH45DE injectors will not survive ethanol, what's the point?
I am getting depressed.
Modified by maxnix at 7:15 PM 4/11/2007
elwesso
2007 BMW M Coupe
maxnix wrote:Nope, $40 for 2.5m.
not sure how you get 2.5m for $40 at $13/foot. Besides, you're supposed to replace your plenum hoses (including fuel hoses) every 4-5 years anyway, long before any fuel hose will break down and or leak!! IMO you get a much better seal with the non-OEM clamps, and personally I like to double clamp the fuel hoses. The fittings give you plenty of room most places!
Tech, one has to wonder if the OEM fuel hose for the Q is not sufficent for use with ethanol, like you mentioned, and that something aftermarket with the ability to withstand ethanol might be a better choice...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:not sure how you get 2.5m for $40 at $13/foot.
Buy using the Nissan part number I sent you.
That part number is A6440-N7686.
Hose is 8mm inner diameter. There is no SAE equivalent.
Modified by maxnix at 1:43 PM 4/11/2007
burijon
I guess the question I should have asked specifically; what is the diameter of the hose that I need? 7.5mm, 8mm etc? Is it all the same size for the Q? What is the code(s) I should look for on the hose to see that it is quality or not?
Are you shaking your head and scoffing me as you look at this link? http://www.international-auto..../8140
Where can I buy quality fuel hose locally? Any local resellers of the Teflon hose like in Techs links? Is Advance, Azone out of the question for hose?
Google mostly shows hot rodders steel braided teflon hose for fuel delivery.
Thanks everybody for answering.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
burijon wrote:Are you shaking your head and scoffing me as you look at this link? http://www.international-auto..../8140
Fuel line hose is gennerally used for carburetors, i.e. - low pressure.
Fuel injector hose is a whole different ball game, and much more expensive. Look for at least a SAE R9 rating. And in a metric size.
Q45tech
SAE R9 "? NOT NOW
EPA currently requires R11-A or R12 as oem hose...................they note that while R9 will probably meet specs for conventional gasoline but absolutely will not meet specs when exposed to 10% ETHANOL [page 30 of pdf].......................permation will be 3 to 5 times higher with 10% ethanol blendhttp://a257.g.akamaitech.net/7...6.pdf......
"Another type of low permeationtechnology for fuel tanks would be totreat the surfaces of plastic fuel tankswith a barrier layer. Two ways ofachieving this are known as fluorinationand sulfonation. The fluorinationprocess causes a chemical reactionwhere exposed hydrogen atoms arereplaced by larger fluorine atoms tocreate a barrier on the surface of the fueltank. In this process, a batch of fueltanks are generally processed postproduction by stacking them in a steelcontainer. The container is then voidedof air and flooded with fluorine gas."
Ethanol sucks the more I research the problems
ponzy
Car: infiniti q45
You can find it in any local shops, especially, in most family-owned parts shop. I've used gates. wes is right make sure you use brand new clamps with screws.
StarPD
Car: 2005 Q45
Q45tech wrote:Unfortunately even old oem hose cannot live with ethanol for an extended period.
Is there a braided stainless steel covered hose with 8mm ID that is suitable for fuel lines on injected cars like the Q? Would it be rated R-11 or R-12, hence resistant to ethanol and/or MTBE?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Somewhere I saw a SAE 13 or something, but the stuff was about as pliable as steel tubing. I don't even think it would do a 5" 90° radius.
burijon
How many clamps do I need for the fuel hose? I'm doing my plenum this next weekend and I don't want to be without anything.
Are these clamps okay? I'm assuming that they will all be 8mm?http://www.ultimategarage.com/...d=34
Thanks!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Old clamps should be fine. Just angle correctly for access after plenum installed.
