If he's using the stock RB20 FPR it's boost referenced. If I was running a decent amount of boost I would upgrade though. The 255lph in-tank pump has been proven to be reliable up to 450 lots of times. I assume the inline version would be pretty similar. I would definitely lose that odd pump configuration. I'm thinking each pump is wired up to the same relay or something. That will kill the power availability on that circuit. Each pump needs it's own hot lead and relay IMO. Troubleshooting wiring from the bench is rough, especially given the vague description.450SX! wrote:I am pretty new to car building so forgive me if this is stupid. is your fuel pressure boost referenced to increase psialong with boost. wondering if at 60% throttle you are getting enough boost to partially overcome the injectors and not enough fuel is spraying in.
how do you know you have no fuel at 60% throttle.do you have a fuel pressure gauge? or is the car stuttering when the throttle is opened up that much.
also is that 60% smashing the pedal to the floor(accelerating hard)or driving steady with the throttle open 60%?
why so many fuel pumps. the one walboro should have been enough for that amount of horsepower?
sorry wrong place thank youRex wrote:Moved to Hybrids
i am not getting enough fuel flow from one pump i have planty presher from one pump i looking at getting 900+ hp (1000cc injectors) rb20 is test engas rpm goes up psi drops because flow drops (6awg for test only)WDRacing wrote:Something I read about quite some time ago was the cooling benefit of the in-tank pumps. I know it's stupidly obvious, but I've read alot of horror stories about using in-line pumps and having them fail. Mostly because they just aren't designed for the prolonged use of daily driving.
The best setup I came across was dual in-tank 255lph pumps. They supported 767whp on a 351 that was running quite a bit of boost. In singular form they have been proven, as I've already said, to easily and reliably support 450whp on 2 liter applications running boost in the 20's.
One thing I'll note. You don't need 100lb or 1000cc injectors when you're only making 450whp. I can make that much with 550's. Larger injectors are harder to control and unless required, simply aren't a good choice. Neither are 3 fuel pumps when a single DOES work just fine.
The problems I see are 100% operator error.
