My car was running fine 2 weeks ago, I started her up and it reach up to 7 psi , but i had some hard time to start my car up. two days later, I started her again , it took me 5 mins to start it up.After I start driving (didn't warm up, cold condition) , the car act funny and wanted to die. so I pulled up to the gas station and checked, one of the spark plug wire (the rubber part) got melt because fuel get in to the spark plug wires. how? here is how
http://imageevent.com/ka24det/densosparkplug I realize that all four spark plug F*** up THEY ARE DENSO that causes the cylinder flood with fuel. today I change out a new set of plug and wire and start her up again. it didn't want to start , and I saw oil dripping from the oil pan, I opened it up and found out fuel get in to my oil pan. My question is that , if there a lot of fuel in the cylinder , would it melt down the piston rings? how bad is that the fuel in the cylinder ? I believe the fuel mixed with the Oil? what should i do? can I just leave it open and let it vapor (oil with fuel). do I need to rebuild my engine?
last question
I already change the setting 270cc to 370cc to my e-mange? I unplug the battery for a week? would it earse all the setting?
