Fuel Gauge
belacopter
Car: 2010 Versa HB 1.8S
I purchased a 10 1.8S HB Versa this past Monday and am loving it so far with one question. I've put on 270 miles so far and my fuel gauge is still over the full line, the same place it was when the dealership filled it up Monday before I left the lot. Is this usual? If not, has anyone else had this issue?
Thanks!
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
Sounds like it's stuck/not working. I'd suggest you fill up the car every 300 miles or so until you have a chance to get it back to the dealer to get it checked out. Plus, you'll be able to tell them you put in "x" number of gallons and the car still registered "full."
Shad0wXCalibur
Car: Nissan Versa SL Sedan
Fuel gauge or sensor in the tank is definitely broken. Depending on how much the car is using right now, you may have actually been close to running on fumes :eek: The fuel tank is small so the range on each tank can only go from 250-720 miles to 400-420 miles if you're one of those lucky ones to get way over the window sticker.
