Here is a pic showing the issue- note how the odometer and gear indicator are cut off on the corners by the trim:
For reference, here is an older pic I took (showing just the odometer, but you can see a good 1/2" of space to the trim).
The trim piece does not seem to be hung up on anything, in fact it seems like a *new* piece. I'm wondering if they changed this at the dealer for some reason, and either put in the wrong part or used a new one that somehow accommodates the changes to the cluster (not likely imo).
Has anyone else noticed this?
