Fuel Gauge Not Working
Creolex
Car: 1995 240sx
95 240sx - Had hose changed on fuel pump and now gauge doesn't work anymore. The person that changed the hose re-checked the float and it is set correctly. Car had been sitting for about two years prior and the fuel pump is brand new.
datsunguy1984
Car: 1996 240sx
sounds like you need a fuel level sending unit. If it was sitting for that long the contacts on the sending unit could have corroded.
centralcoaster33
Car: 1997 Nissan 240SX #5
It might be possible to clean those, likely easier to replace. Until then, fill up each time and reset your trip odometer. Get gas at 280 mile intervals to be safe.
