wankelTII »
https://forums.nicoclub.com/wankeltii-u48978.html
Tue Nov 07, 2006 11:45 am
Its not the float if the gauge makes sudden changes, you could have corrosion on the rheostat or variable resistor in the sending unit itself. Which would mean you need a new sending unit. But you should get hold of a digital multimeter first and figure out what is going on. Does the needle make crazy movements all the time or is it only when driving or what.The gauge is probably less likely to be faulty than the sending unit.
