trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Thu Apr 24, 2003 11:40 am
The needle problem is probably the indicator riser. It's in teh fuel tank and I think can be removed when you do the fuel pump. I'd say it's almost surely that, and if you're in there do the fuel pump to, hell, put in a Walbro 255lph, it's only $100. Do the fuel filter, it's $13. Yes, an S13 should get about 350 miles to the tank, I got 375 from full to the light turning on. Also, use the SEARCH function and search for "gas mileage" and you'll find a ton of results, I recently posted a list of everything it coudl possibly be.
