Because I have factory warranty still. I'm trying to avoid paying for it at this moment.datechboss101 wrote: ↑Mon Apr 02, 2018 3:00 pmWhy the heck would you take it to a dealer? Take it to a local trustworthy 4.5 star or 5 star rate independent mechanic. And then have him figure out if its normal or not.
Factory warranty on yours will end soon as its been almost 3 years, depending on the date you got your 2015 Rogue. I would do this ASAP, so it would be covered under the 3yr/36k mile warranty.LuckySeven wrote: ↑Mon Apr 02, 2018 6:49 pmBecause I have factory warranty still. I'm trying to avoid paying for it at this moment.datechboss101 wrote: ↑Mon Apr 02, 2018 3:00 pmWhy the heck would you take it to a dealer? Take it to a local trustworthy 4.5 star or 5 star rate independent mechanic. And then have him figure out if its normal or not.
The dealer should give a warranty on their work, so if anything happens during the time of the warranty, then they would fix it for free.LuckySeven wrote: ↑Wed Apr 04, 2018 11:27 amTook it in and they found the problem. It wasn't the fuel gauge. It was the heater/blend door etc mechanism. It was occuring just when the car is left on front windshield defrost only (I didn't even realize) it's like flapping/clicking loudly and they said they need to order the parts in as they can't just replace the one small thing that's causing it and have to replace the whole assembly under the dash. They said the dash may have to come out and now I'm worried there will be more creaks rattles after they are done.
