Teggyroadspecialist »
https://forums.nicoclub.com/teggyroadspecialist-u261195.html
Mon Mar 28, 2016 5:41 am
I went to the local Junkyard (here in Florida), and found a 300zx. When I took out the fuel pump out it looked very similar, almost identical. The float bar is the same, only difference is the 300zx has an orange one. Anywho, I saw the fuel sender thing you're talking about and the copper wire coil thing was all wound up around the silver bar that holds the float bar. So, I am assuming that you were right about the fuel sender not making enough contact, causing it to fluctuate.
I have no idea how to go about fixing this. I might buy another assembly, (a new to me one, used). Or, go see this guy that my importer told about. They say he has fixed the gauge on other gts-ts before. Only problem is, he is four hours away. Hoping that the job won't take more than a day, I could just hang out in town over there.
