chaunceysj »
https://forums.nicoclub.com/chaunceysj-u135737.html
Sat Nov 21, 2009 10:07 am
thanks evil. i pulled out the whole unit, and repaced it with a junk yard unit i picked up. i pluged it in b4 putting it into the tank (without the pump) and played around moving the float level. the gauge then moved. however once i put the pump in and dropped it in the tank. i presume i did it right i payed close attention to the removal, and it seams according to the fuel lines it cant go any other way i havent gotten any movement. i put it in at a full tank, and have now driven about 72 miles and the gauge still reads full(gauge points slightly over top line) so i cant remeber if 72 miles can still equal a full tank or is somthing still wrong?
