This is odd. This happens alot if the torque convertor clutch is engaged all the time, but this would not cause the problems you described before. They could be two separate issues but its hard to tell without looking at the car.Luntha wrote:Thank you both for your reply I will check the ECU.
There is another things that is occuring that I failed to mention. The engine would stall out when I shift the car into reverse. What would be the cause of that?
