0range_240 »
https://forums.nicoclub.com/0range-240-u916.html
Wed Jan 21, 2004 6:16 pm
Hi, welcome to the forums =)
when I had to replace my old fuel filter I replaced it with a Z32 300zx filter (1990 and newer)
The benefit is that its physically much larger, allowing fuel to flow through it faster (theoretically) ... however I doubt you would see a performance gain from it, maybe better throttle response though. There are no negative or drawbacks to using one, only that because they are larger, installing it MIGHT be more difficult than a stock filter, but I had very little problems with mine.. just put the new bigger filter in the same bracket the old one was sitting in. Hope this helps =D
