Fuel Filter
Black94Jay
Where is the fuel filter located on a '94 J30t? Also, how often is it recommended to be changed; (miles or length of time installed) Any particular brand to use in replacing?:help
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
Personally I would only use an OEM Nissan fuel filter every 15k miles. It's a bright silver can about 3" diameter & 3" tall. It has a rubber line going in the bottom & a rubber line coming out of the top with an extra rubber sheathing around it that has large holes all over it.
On my Sentra, it was located low on the driver's side firewall, on my Q, it's on the pass side strut tower, also kinda low, the Pathfinder....er....uh...can't remember. (time to change the filter on the wife's car)
If you still can't find it, find the fuel rail & look for a line coming out of either end of either side, trace it from there & you'll find it. There's a clamp on both sides, you'll need a small screwdriver.
BTW, at least release the pressure in the fuel tank by unscrewing the gas tank cap before starting. Others will tell you to pull the fuel pump fuse & try to start the car, releasing any pressure in the system. If the car has been sitting overnight, you probably won't have much pressure to release. There's a valve by the tank that's supposed to keep the pressure from falling, but on a ten year old car, it probably leaks down overnight pretty quickly.
Black94Jay
Heavyduty:
Apreciate the reply. I am not going to do the work. I found a garage in Tampa that works on basically Asian manufactured cars. They have supposdly a good reputation and use only OEM parts. I went by this morning and they are going to get the filter today and install tomorrow morning. The local Infiniti dealer is not the place I will take the car. The J30t is my wife's car, has only 58,000 miles on it. Basically sits in our garage, other than her running errands, etc. She likes the car and we don't want to cannibalize it with just any replacement part. Keeping it strictly stock from the Infiniti plant. Thanks again !!!
