fuel filter
shurd
Car: frontier
how to replace a fuel filter on 1993 240 sx
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
if you cant figure this one out on your own...maybe you should have it done.
here ill do a write up real quick.
step one. locate filter on the passenger side strut tower, its that little cylindrical thing with two rubber fuel hoses running too it.
step two. remove both hose clamps with slip joint pliers
step three. remove both hoses off the filter
step four. remove filter and throw away
step five. take new filter and make sure the arrow is pointing up
step six. put hoses back on
step seven. reinstall hose clamps
step eight. stand back and feel retarded that you couldnt figure this out on your own
93240cooool
Car: 1993 240sx
lol i seriously did this in ten minutes the hardest thing is getting the hoses off.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
You should 100% do it this way!\/\/\/Step 1: Buy a 1990 300zxtt fuel filter. Step 2: Download a FSM. Step 3: Read FSM. Step 4: Replace fuel filter.
OrRelieve fuel pressure, Wrap a rag around the fuel filter to catch any spilled gas, Un-screw top and bottom fuel hose clamps, pull out old filter, install new filter on fuel line, tighten clamps and done.
If you spill gas anywhere, spray some watter in that area so you don't catch your car on fire.
shurd
Car: frontier
Thanks for the help. The rubber hoses need to be replaced. Would Napa or Autozone know what grade rubber hose I need if I told them what they're going to be used for?
93240cooool
Car: 1993 240sx
shurd wrote:Thanks for the help. The rubber hoses need to be replaced. Would Napa or Autozone know what grade rubber hose I need if I told them what they're going to be used for?
yes..
shurd
Car: frontier
Thanks. 248,000 miles and still rolling!
sr20detman
Car: 89 s13 coupe
you can buy fuel hose thats the proper grade and just cut it to fit also. that might be cheaper.
thats what i did.
just make sure its the right kind.
MastaYu
Car: 92 Nissan 240SX SE HB
if you just look a the fuel filter its pretty self explanatory on how to isntall it
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
Don't spill any fuel on the paint
