fuel filter...
ceenotes1
Car: chess, fixing things that dont work
how in the world do you change the fuel filter on the 93 j30????? that space is so cramped only a child with small tools can fit his hands in there!!! same goes for the dual pcv valves...hmphhh
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Best thing to do is to undo the upper hose, and then loosen the lower hose enough that you can pull it off (carefully)......
Also, make sure that you take out the fuse to the fuel pump, and give it a few cranks (if you dont, the premium unleaded floodgates will open)
