Fuel Filter replacement.
jontyler
Car: 1998 240SX SE
Ok. I'm in the middle of tuning up my car. So far I've replaced the gear oil and put new ngk iridium plugs and ngk wires.
So I've read how to replace the fuel filter in 'how to' section. Does anyone have any tips on how to do this easier? I couldn't even the clamp on the bottom tube loosened? Any help would greatly be apprciated.
Also, I've ordered a new distributor cap. Are there any precautions I need to take? Or is it just plug and play ; ). DO I need to replace the rotor too?
Malac0da13
Car: 1992 Nissan 240SX Convertible
i couldnt get the hose off my fuel filter and ended up having to cut the hose off of it...
Joe
alot of times the lines are very stuck on the filter remove the clamps, then grab the filter with your hand, grab the hose with a pliers (try not to damage it) and twist. that will break all the crap on the inside that is stuck off.
mrzabala
Car: 93 Nissan 240SX SE Hatch
Relieve the pressure by opening your gas cap. Usually pliers will do the job and a little muscle. If things dont turn out, use some carb cleaner and spray all around the line. This will expand the line, but if you do this too many times or spray too much, the line will break down.
NotDave
Car: 96 240sx that needs paint
pretty much just take out the old and put in the new. gas will spill but its supposed to.
jontyler
Car: 1998 240SX SE
Thanks fellas. Easier said than done though. I'll try the pliers. I sure don't want damage the line.
180fan
Car: 89 fastback
wrap up the pliers with some duct tape before you grip it and turn. either that or now may be a good time to replace your old fuel lines too.
jontyler
Car: 1998 240SX SE
yeah I was thinking about just replacing the fuel lines too while I'm at it. Good idea on the duct tape.
Enlefo
Car: s14 zenki, black on black.
Take out the fuel pump fuse and start your car... it will run for a few seconds then die. This is the proper way to relieve your fuel system pressure. Be ready for a bit of fuel to spill out when you unplug the sucker. Also a 300zx fuel filter will fit just fine and give you better flow... not a hue increase or anything but the filters cost the same.
bone_stock_240
Car: 1995 Infiniti Q45
Mine was ridiculously hard to take off. I used some boiling water to try and soften/expand the line. After alot of pulling and twisting and swearing, I managed to get it off.
ZiG
Car: 1993 240sx coupe
I wore gloves. After relieving the fuel pressure, I took off the bottom line first, put my finger over the bottom where gas was leaking out, then took the glove off and stretched it around the filter, so it kept all the gas contained. there's my tip.
