Fuel Filter Replacement, Replacement Shocks for 1997 QX4
slshearer
Car: 1990 Q45 Silver/Blue Interior, 2nd owner since 1992, 18" Premium Wheels, 245/45/zr18 Tires, Blue Tok
Hello,
I have a problem with the sliding interior cover for the sunroof, it seems to have some play when pulling or returning to the cosed position, anybody know what the fix is?
My power antenna stopped going up and down, there is no noise from the motor, I checked the / replaced fuse, still no go, so I took the inner fender cover off and checked the power which it has, Is the Infinty power antenna the same as the Pathfinder? I think the electric motor died.
I recently replaced the fuel filter on my QX4, the new filter had one end stating out and the original one I removed had nothing t indicate flow, the filters were similiar with a raised band on one end so I matched the bands whcih put the out on the same the side as the right rear wheel, is this correct? If I put it in wrong what can happen?
I am ready to install some new shcoks and was considering using Pathfinder shocks to save a couple of $$ are the QX4 different?
Thanks!
Modified by slshearer at 9:15 PM 5/6/2008
Modified by slshearer at 9:23 PM 5/6/2008
Issac
Car: 2002 Pathfinder, 1995 Q45
Your fine on the filter if you copied your other.I think the shocks in rear are the same.
