Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri May 16, 2003 8:25 am
There are at least 15 different types of hose pullers for various size hoses......the trick is to lube the inside of hose with special secret ingredients so the next time it comes off easy! Special silicone hose lube.
When you get paid flat rate, every tool you buy must save you time to pay for it............why do you think the guys buy $25,000 to $40,000 in tools and $9,000 tool boxes to hold them.........takes 5-10 years to build up to this level.
The problem is the time to get the car into the stall, secure the filter from parts department, open hood change filter [90-96] [97+ requires a lift], close hood drive it out, fill in paper work etc.
You can't even change a bulb on a car in less than 30 minutes if that is the sole task.....unless you do it in the parking lot for free.
Why most filters are bundled with a 30k/60k service.
