Fuel Filter Replaced = Worse MPG?
Khronik
Car: Pearl White - 91 N/A 2+2 Auto (RIP)
Arctic White - 96 N/A 2+0 5spd (SOLD)
Aztec Red - 90 TT 2+0 5spd (DD)
- Megan Racing DP's
- Borla Catback exhaust
- CZP ECU Upgrade
- SZ High 5 Clutch
I decided to replace my fuel filter (bought from autozone), it looked bigger but the previous owner(s) had done alot of ghetto fixes so im not sure if that was the right one, but it did fit perfectly in the holding bracket..
this fuel filter from autozone doesnt fit in the holding bracket with the two ends of the bracket touching, I had to use a longer bolt to hold them and theres about a 0.5inch gap in between the bracket ends
I was getting an average of 310miles on a full tank for my weekly drive, and now im getting about 280-290 :wtf2:
any ideas?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Go to a different store and see what filter they hand you. Or try an OEM. How was it running before?
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
driveability hasnt changed much, it seems to run smoother now but at the cost of 20miles
going to go to the same store today and see if they come up with a different filter and check another store
see what happens
maybe O2's are bad..
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I wonder how clogged up it was. I dunno if it is running fine, not rich or lean perhaps it's just because it's flowing more freely.
A Paratroopers 300zx
Car: 1992 Nissan 300zx Twin Turbo
2004 Toyota MR-S
Any possibility of it being installed backwards? If it was accidentally installed backwards... flow of the fuel would be hindered. Just a thought. Also, try another brand of filter. Wix and Fram are pretty decent.
es.biggs
Car: 1990 300ZX 5sp NA
Are you positive your driving habits haven't changed at all? If you fill up with 16 gallons that is a little over 1 mpg...driving a little bit more spirited even just a couple times can have that effect.
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
i didnt install it backwards as far as i know, the flat of the filter is facing the engine like the previous one
driving hasnt changed much I tend to give some throttle every now and then the first tank was about 30miles short of my usual mark and that was pretty much granny driving, this last tank was 20miles short and I had punched it once to 90 and was playing tag with a BMW down the highway one day
would think the last woulda been short 30miles if anything, not the other way around
*** didnt get a chance to check for filters yesterday got stuck at work....
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
checked the book at another store and got the same size filter as was originally on there
anyone ever had power loss from clogged filters?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
blockage creates flow resistance which leans it out some. So yeah.
Khronik
- Megan Racing DP's
- CZP ECU Upgrade
- SZ High 5 Clutch
dunno how clogged the original was, but I still have and it probably weighs a good 5pounds
with the new CORRECT filter, im able to get 2nd to spin again, and 3rd spins in high rpms thought my clutch was going out but apparently not
