Fuel Filter Change/Sluggish Pickup
Antjaw
Guys, My car runs sluggish for a 240.. Of course it has 150,000 miles on it. Anyway, I figure I will go ahead and change the fuel filter since its cheap and easy.. Maybe it will make a difference.I have heard and read that you should use a filter made for a 300z twin turbo.. My question is:Which one should I buy.. year and such, and what difference will I see between a standard 240sx filter vs a 300z?
Thanks for your input.. also any other ideas about the sluggish"ness".
b240
Needs a complete tune-up perhaps?
DonDonati88
Yeah or maybe a new engine...
Antjaw
anybody have an answer for the filter question?
Nils
Car: road racing
Antjaw wrote:anybody have an answer for the filter question?
You got a stock 240sx with 150000 miles on it... trust me, a 300zx fuel filter wont make a difference in performance.
lol
Just go and buy a stock 240sx fuel filter.
nils
sethulrich
Car: S13 240SX Fastback KA24DET - GTiR T28 + 550cc injectors + Z32 MAF + RS-Enthalpy tune
300ZX fuel filter doesn't cost much more than a 240SX fuel filter...if at all. and it's a direct fit anyway. may as well get the 300ZX filter.
chezina
@Antjaw: All 300ZX(Z32) fuelfilters are the same(from nonturbo to tt), and over here the Z32 filter was CHEAPER than the stock filter(CA18DET).:cool:
Antjaw
Thanks much chezina Gonna go buy one today.. I will let you guys know if I notice a change in performance.
Calvin
The 300z filter usually is priced lower, but it is larger and therefore doesn't fit as well into the smaller 240sx bracket. As far as I know, the internal design and medium are the same. There is NO performance advantage to putting a 300z filter on a stock 240sx motor.
As far as sluggishness... could be a million different small things. You might want to do a compression test to determine overall health of your engine. I believe 240sx.org/faq has the instructions. Otherwise, start with the basics... check ignition timing with a light, new air filter, spark plugs (NGK), wires, rotor, and so on. You might need a new O2 sensor if mileage is bad. Don't waste money on snake-oils. Do everything yourself or you get ripped off.
