Fuel Filter Change - 91 240sx
FRbeliever
Car: S13 PS13 RPS13 SILVIA 180SX 200SX 240SX SILEIGHTY ONE-VIA
I've never changed the fuel filter before, where is it located? What are the procedures? Do I need to watch out for something, any tips and tricks? Easy to change? Thanks guys!
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Its right next to the intake manifold,Just open your gas filler cap and leave it off untill your done.Its a very easy job to do,Maybe 5min.The hardest part will be getting the fuel line off the old filter,Use WD-40 it helps alot!
dfw240_EE
Car: 1992 240SX
^^^What he said
I had a worse time, I discovered that I had SAE standard (5/8" I think but can't remember) Carbeurator low pressure hose on mine!!!! Needless to say it was leaking. Since Nissan uses metric, the old one was the wrong size and was on tight!
FRbeliever
Thanks, yes it was easy, took me 10 to 15 mins.
anyotherone
Car: '93 S13 coupe VH45
Mine was rediculesly hard to get the lines off of... don't plan on it only taking 15mins... plan for 45, then if it only takes 15 you can be happy.
Bustadust240sx
lol i have a dodge stealth (mitsibishi motor) it took me 2 hours to change the freakin fuel filter on dat bad boy
