SavG35 wrote:First thing first, its simple but key. Tire pressure, check it constantly, or as most of have,make sure your tire gauges that are inside the tire are correct. I also replaced all my tires with Nitrogen and got 1 or 2 more miles. Anything that will lighten the load on the engine and return power to your the wheels would help. I am about to install all new UD light weight pulleys on my 04 g35 coupe, I'll let you know what I get from that. Also I have been looking all through this forum and others to figure out my best intake upgrade. What I have come up with is that the G's intake system really is not bad, other then a Z-tube you won't get much if any from that. I am heavily thinking on getting the Kinedix V+ plenum, it seems to give the most power and MPG results.
Now really no matter what you upgrade it all comes down to how you drive. Now if you upgrade everything and drive easy then yes you can see some more MPGs. So there you go thats what I got. I 'll let you know what I get when I add the pulleys, and the plenum.
You guys have two completely different cars. Comparing MPG mods isn't going to work.
Probably the most effective way to increase MPG in the G would be a different final drive ratio to bring the RPM back down at cruise.
It's possible to have the target closed loop values to be a little higher than stoic to shave a little more, but you'd have to be gentle with it and not drive in high gear with a load. Then again, it would probably go out of closed loop if enough load was present.
