Evanarc wrote:Alright guys i need some more advice..I previously posted about a sputtering and bucking problem, along with a fuel smell in the cabin.sometimes theres a weird clunk but idk if its relative.
I cleaned the MAF sensor and that helped but it still drives like s---I also did a bunch of standard maintenance I thought might help
My friends dad, the mercedes guy, up the street took a good short look at it and said fuel injectors.
Im prayin its not the fuel injectors nor does it feel like thats my problem. I did a jiffy lube fuel rail flush. BG44k etc
Heres some more symptoms,
-Its rattles alot when you crank it for the first time of the day
-then 9/10 times will stall immediately, or 10/10 the idle is droppin like crazy
-once you get it in drive it usually fine besides the heavy bucking andbouncy idles.
-It will rarely stall at this point.
I think it might be the fuel pump and/or a leak in the plenum hose.
I dont believe the prior owner ever changed the hoses among other things, I curse him for in my sleep..
has anyone ever been to this sad point before?what gets replaced first on the road to fixing this issue?
What's the fuel pump sounding like? Do you hear a sort of buzzing sound? Like a swarm of bees in the trunk. I totally recommend ohming the injectors. If it is the injectors, at least you know what the problem is. If it isn't, then at least you can rule it out.
Go to the car and turn the key. Don't start it. Just turn the key to "ON" and listen for the fuel pump priming. If it's really loud, or you can hear it while driving, that may be the culprit.
The fuel smell in the cabin could be a leaky hose. It's usually the one in the rear of the engine, close to the firewall. It's really noticeable in the cold. Especially right after starting the car. The hose will begin to swell as it warms up and it seals the leak. (If the hoses are old, it'll be like small holes that close easily after warming) Tightening the clamp on it helps, but replacing it is the best solution.
Now that's assuming it's coming from the front. If you have a heavy fuel smell in the cabin and it's strong in the trunk, it could be the o-ring seal around the fuel pump.
