FairladyFan »
https://forums.nicoclub.com/fairladyfan-u131094.html
Fri Nov 04, 2011 8:53 am
Hey guys.
So after 13 months I finally got my car all back together but it won't start. (It cranks over strong and nothing sparks or lights on fire so I must be on the right track. Haha)
First thing I tried was pulling the number 1 and 3 plugs. Both came out dry after lots of cranking and would spark when held against the plenum.
Next I pulled my return fuel line and made sure fuel was making it there. It was.
Next I pulled my CAS and listened for my injectors. All six are firing in as far as I can tell the right order.
So I cranked some more and pulled the plugs again. Still dry.
Next I tried some starting fluid into the intake and she fired for a sec and would die as soon as the starting fluid was burned up.
So I'm thinking the next step is to test the fuel pressure (perhaps my FPR crapped out from sitting dry for a year)
I was wondering where in the system I T in a gauge? I know it has to be before the FPR but does it also need to be after the dampener?
Any other suggestions on what to check?
Thanks in advance for the help.
