fuel cut VS ign cut VS boost leak ?
Silverbullet
ok, i have a little situation. My car ran perfectly fine before. Just a few days ago, im expiriencing some type of cut. I figure it is a fuel cut, but im running stock everything so it dosnt make any sense. I'm only runing 7psi, Walbro 255 pump, and Z32 filter. I did some more runs on the highway just now and i've observed this only happens in high RPMs and full boost. It happens anywhere from 4000RPM to redline on full boost so it makes sense to me that its some type of fuel cut. Whats wierd is there is no other symptoms. I dont have idling problems, i dont have stalling out problems, i dont have any hesitation, spuddering, or studdering. Anyone have any ideas? i am stumped. Oh yea, it might possibly be a boost leak or an ign cut, but im leaning more towards this being a fuel cut problem because i dont notice any extra backfire or huge fireballs after my loss of power. I did some searching and most ppl who have identical problem with me ususally have their cars spudder or have crazy idle or something. Mine dosn't seem to do anything else at all.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
i have a similar problem, if i hit the gas hard in 1st or 2nd gear it willbreak up like a sob once it reaches full boost. I checked all my connections trying to find a boost leak and i cannot find any. i tried cleaning the MAF, replacing coil packs and trying a different FPR... none worked.
onr240sxse
Car: 93 s13 coupe 93 s13 hatchback
I know this is old BUT do y'all figure this problem out? Mine is doing the exact same thing.
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
Sounds like a spark plug issue. In the absence of any other symptom, I think the problem is either the spark temperature or the spark plug gap. Most like the gap. Gap your spark plugs to .28 and do a run. Also i run plugs in the 7 heat range. Seems to be a optimal heat rage for SR's and high boost.
