Fuel cut off switch article , Cheap security device
le_ryan
Car: Mazda3
91 Nissan 240SX SR
[Ninja edit]
Modified by vroom-chirp at 9:54 PM 12/16/2006
ZiG
Car: 1993 240sx coupe
Running that much current through a toggle switch is a bad idea. I've got mine wired to interrupt the power going to the fuel pump relay signal.
neverlift
or you could be even cheaper and hit the junk yard for an actual fuel cut off off a ford.
YRUSOSLO
Car: '89 240 hatch
Do a write up on it. We wanna see.
driftin8ez
Car: 92 Coupe, Turbo Miata
ZiG wrote:Running that much current through a toggle switch is a bad idea. I've got mine wired to interrupt the power going to the fuel pump relay signal.
That was i was trying to say in his other post but no one seems to care. When there car is on fire or to a lesser extent they cant get it started because of improper wiring and a burnt out switch... oh well. It is much safer to cut the wire at the ecu for the fuel pump relay and put a switch on that. Much lower volts. But do what you want.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
its a 30amp switch for a 10amp fuse, and if the switch gets over loaded, it will blow the fuse just like its suppose to.
driftin8ez
alright tomato toe(mah)toe i guess....
RyanAwesome
Car: Murdered out coupe.
driftin8nez wrote:That was i was trying to say in his other post but no one seems to care. When there car is on fire or to a lesser extent they cant get it started because of improper wiring and a burnt out switch... oh well. It is much safer to cut the wire at the ecu for the fuel pump relay and put a switch on that. Much lower volts. But do what you want.
much safer and cleaner looking, all the wires stay inside the car. Just about all switches in a modern car are ground side controlled.
neverlift
thats why I do all mine on the + side
DrFtKiNg180sx
driftin8nez wrote: It is much safer to cut the wire at the ecu for the fuel pump relay and put a switch on that. Much lower volts.
And how do I find that wire??
driftin8ez
DrFtKiNg180sx wrote:And how do I find that wire??
I can help you by telling you what you should post so you can get an accurate answer. I assume you have a 240 seeing as that is the section we are in but what year and also what engine. The ecu pinouts differ between a CA,SR,KA,RB. (like how i listed from smallest to biggest)
ZiG
I know, but it seems that lots of people are dumb and decide it's a good idea to run the power wire inside the car like that. I wonder what it does to the fuel pump? I mean, these people can say they dont care or they dont think the switch will have a problem with it, but the bottom line is that it's the wrong way to do it. And it isnt any harder to simply splice into the fuel pump relay and use that wire.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
Im sure your route would be cleaner, and mabey safer, You should make a write up on it, i'd like to see it. I just threw this together for AzHitman, i originally dropped this article but it was requested to be made again.
RyanAwesome
I dont mean to be a d!ck. But i dont think its a very good idea to make a writeup on a massive forum that could possibly cause problems and at the worst case a fire in the car.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
I was leary about that too, but the man himself requested the write-up,
RyanAwesome wrote:I dont mean to be a d!ck. But i dont think its a very good idea to make a writeup on a massive forum that could possibly cause problems and at the worst case a fire in the car.
RyanAwesome
How bout one on the control side of the fuel pump relay instead? Please? You could be saving some innocent s chassis'! Think of the s chassis'!!!
ZiG
RyanAwesome wrote:How bout one on the control side of the fuel pump relay instead? Please? You could be saving some innocent s chassis'! Think of the s chassis'!!!
Eeeexactly. It's weird.. I have an 86 trans am and on all of my 'redneck' trans am forums (thirdgen.org) you NEVER see people doing things like this.. My favorite is still the writeup where the guy puts the e-fan in his s14 and powers it with a radio shack switch and not even so much as a fuse.
driftin8ez
Ok I'm going to try and locate the pin outs for all year 240's and all the different engines. If i can make a list of where this wire is on all those cars I will take apart mine car and snap some pics of my finished product and make a write-up. Without a list of pin outs the write-up is basically pointless so let me work on that first.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
driftin8nez wrote:Ok I'm going to try and locate the pin outs for all year 240's and all the different engines. If i can make a list of where this wire is on all those cars I will take apart mine car and snap some pics of my finished product and make a write-up. Without a list of pin outs the write-up is basically pointless so let me work on that first.
lookin forward to it
