Fuel cut Help
grk nickafis
Car: Looking for something fun.
2011 GMC Sierra
A while back my car would just lose power as if i let off the gas and hit the brakes and i could floor it all i want, it wouldn't move. I swapped my PTU and it was done. Now, I adjusted my TPS and IACV and its back. I'm going to try tuning the TPS and IACV propperly. If that doesn't work, any ideas?
grk nickafis
2011 GMC Sierra
Thanks
es.biggs
Car: 1990 300ZX 5sp NA
Did you fix it by re-adjusting the TPS and IACV
grk nickafis
2011 GMC Sierra
not really. if i keep the rpms steady at 2k it sounds like a misfire and wen i rev and the rpms come down, they drop down like 100rpms past idle and bounce back up to normal idle every time i do that. I dont know which wires to get the voltage from for the TPS either.
es.biggs
http://www.pexcom.com.au/z32cms/e107_pl ... ontent.335
You gotta use a multimeter to check voltage at the middle wire on the TPS connector - not the connector on the sensor, but the gray connector below the sensor. Ground the other lead.
I stuck a sewing needle into the middle wire on the connector, then held the multimeter lead to the pin - you have to leave it connected. You have to look up the specs, its in the service manual and its all over the forums, but I can't remember off the top of my head.
grk nickafis
2011 GMC Sierra
thanks thats really helpful haha i tried taking the connector apart last time but couldnt. ill try that
