Fuel cut FTL
lilRillo
Car: S14 Kouki SR20
Hit fuel cut for the first time today kind of a bumber...oh well im pretty sure its my s***ty stock fuel pump if finally gave out on me, time for a wallbro 255
LugNut18
Car: 1992 240sx Hatchback
lilRillo wrote:Hit fuel cut for the first time today kind of a bumber...oh well im pretty sure its my s***ty stock fuel pump if finally gave out on me, time for a wallbro 255
So were you speeding or did your fuel pump just cut out? If you were speeding I hope it wasn't on public roads
lilRillo
Car: S14 Kouki SR20
Wasnt speeding at all was going up a mountain in my town and then i started to bog at higher rpms then i went to my lot and did a second gear 40 roll and BAM bogged at 5k rpms when it shoulda been 7k
E7-S14
Car: ess 14 foo!
sounds fishy...
lilRillo
Car: S14 Kouki SR20
as in it could be more then my sh*ty stock fuel pump? once i put it in i was going to get a tune too
LugNut18
lilRillo wrote:Wasnt speeding at all was going up a mountain in my town and then i started to bog at higher rpms then i went to my lot and did a second gear 40 roll and BAM bogged at 5k rpms when it shoulda been 7k
So you were speeding
jk, but in all seriousness, did you have enough gas in the tank? If it bogged up hill, you might have a fuel pick up problem
lilRillo
Car: S14 Kouki SR20
yeah man had a quarter of a tank and ive been close to E before and never hit fuel cut
LugNut18
haha we have the same number of posts..........not anymore , I'm winning
LugNut18
lilRillo wrote:yeah man had a quarter of a tank and ive been close to E before and never hit fuel cut
Did it only cut out going up hill?
lilRillo
Car: S14 Kouki SR20
lol i just hope thats all it is tho my sh*t stock fuel pump finally giving up after 900 miles of my SR hahah
LugNut18
lilRillo wrote:lol i just hope thats all it is tho my sh*t stock fuel pump finally giving up after 900 miles of my SR hahah
It could be, I have my own fuel pump problems to deal with too. Chances are I'll be replacing it with a 255 as wel
lilRillo
Car: S14 Kouki SR20
nope on flat ground too
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Lol should have worded this thread differnt. Now everyone thinks that you were going 110. But anyway throw a inline fuel pressure gauge on it and monitor your fuel pressure, should be 36-40psi with a good pump.
lilRillo
Car: S14 Kouki SR20
lol only 60 on my private lot and 40 up the hill speed limit was 35 , how much does one run? and the car runs fine and low rpms its just higher rpms it hits it hard
LugNut18
nissans13240sx wrote:Lol should have worded this thread differnt. Now everyone thinks that you were going 110. But anyway throw a inline fuel pressure gauge on it and monitor your fuel pressure, should be 36-40psi with a good pump.
That was the next thing I was gonna say. If fuel pressure is good, maybe you have an ignition miss. Maybe a bad ground somewhere.
lilRillo
Car: S14 Kouki SR20
Hmm well i am bringing it to a local shop tomorrow for further inspection, hopefully it is just the fuel pump not giving enough gas to the engine at higher rpms but who knows
LugNut18
lilRillo wrote:Hmm well i am bringing it to a local shop tomorrow for further inspection, hopefully it is just the fuel pump not giving enough gas to the engine at higher rpms but who knows
I know the KA is different from the Sr, but I had the same problem. Turns out I had some bad grounds, I fixed them, and had no problem since but good luck.
lilRillo
Car: S14 Kouki SR20
Yeah that could be the prob too idk ill have them check it all out but i still wanna get the wallbro 255 and a tune 18 lbs of boost!
LugNut18
lilRillo wrote:Yeah that could be the prob too idk ill have them check it all out but i still wanna get the wallbro 255 and a tune 18 lbs of boost!
Damn, that's gonna be nice.
lilRillo
Car: S14 Kouki SR20
hahah thanks man ill keep you guys posted on it
AZ89two4Tsx
Could be many other things.
lilRillo
Car: S14 Kouki SR20
Such as....
AZ89two4Tsx
Is your speedo working? It could trick the ECU into hitting the speed limiter.
Could be the ECU itself.
Speed sensor.
And probably some other things I can't think about off the top of my head.
lilRillo
Car: S14 Kouki SR20
Speedo and rpms works and fuel n temp both work... idk it was really random tho because yesterday car ran fine then today this happens. weird. but hopefully its not my ECU i really hope its just my fuel pump just cant keep up anymore, it is stock and im pretty sure its still the original so it has 170k miles on it.
