fuel cut defender
JICdrifter
will a fuel cut defender remove the factory boost cut so i can run more than the factory 10psi?
rico05
Car: 1992 RMS13 w/ CA18DET
No. FCD do just that: they stop fuel cut, which is different than boost cut. Boost cut happens when the MAF sees the volume of air flow past at the equalivent of 9-11psi (which it actually reads in a voltage signal, 5v to be precise) Fuel cut is another matter. Fuel cut happens as a kind of rev limiter. At a certian RPM, ECU cuts fuel to save the motor from over revving IIRC.
02 Black Spec V
Car: 2002 Nissan Sentra SE-R Spec V
how do you get rid of the stock boost cut?
float_6969
Get a bigger MAFS. (which will require either an ECU burn or a SAFC)
JICdrifter
from what i am told, it modifies the maf signal so then u can run higher boost.
02 Black Spec V
float_6969 wrote:Get a bigger MAFS. (which will require either an ECU burn or a SAFC)
OK so if you want a Z32 MAF you can get a SAFC insted of flashing your computer? How would you tune it then?
sil_eightyRPS13
Car: 1989 RB27 cefiro
JICdrifter
the number 5 pin? does that really work?
float_6969
I don't think that is going to work on most swapped cars in the US because most people are just plugging the wastegate actuator directly to a vac/pres source.
