maineimport wrote:Your 5th gear sensor is probably toast (may or may not be attributable to your redline fandango). The 5th gear sensor acts as a backup to the speed governor. When you are in 5th it engauges the 5000rpm rev limiter.
Try disconnecting it and it shouldwork fine. If that doesn't work then get back to us.
