fuel crisis! losing my precious gas!
JXN
Car: Nissan 240sx S13 hatch
2 days ago i just filled my tank full cuz i knew the gas price would raise....but today, after drive about 125 mi. I have a little bit below the half tank mark! Of those 125 mi, 90 of them are highway miles!
This is ridicules...maybe im paranoid about precious petro...but I think I have a leak or something...my fuel tank aint dripping...
what do yall think? is my car leakin precious fuel or is it just me?
zippitta
Car: 1990 240SX HB
ouch...sounds like someone might be the victm of a syphoning...lol. It is very possible that you are leaking...just check for leaks in the engine bay, at different times. Like when it is cold or when it is at running temp, things like that and also try staying alert to the smell of the gasoline.
JXN
lol this reminds me a funny joke i heard in classs....
dont try to check for gasoline leak with FIRE! lol
navysnail
see if your engine is rich too...
although thats a very sudden drop...
babowc
Car: 240sx
see if yoru is rich +2,
it could be a bad sensor.. my mom's xg350 ate up gas when it had a bad sensor..
and what is your idle at?.. that COULD be a reason.. but you said 90 of it was highway.. so, maybe not :/
just wait for nistech or other experts to get on this thread, they'll help alot
NISTECH
What s more important here is how many miles per tank did you use to get? Most cars can not quite get 300 miles per tank. You say your at 125 at half a tank. If its off its not a whole lot off. Also remember since we are in california we are at the time of year where they start changing fuel mixture over to oxygenated stuff which also effects fuel milage. Its a little early but it may be due to recent events they decided to go in a bit early. In any case if you determine you are slightly rich take a look at your ground on your airflow see if it is within spec,few threads on that here.
JXN
idling normally...at 750 RPM(altho it DOES have that fluctuation every now and then... IAAV i think?)
get about 24-26 MPG on an average
Last time i checked with the scanner, it WAS rich...but said OK to drive. Was still getting good mpg back then.
Btw my check engine light is on for that smog code.
check this out:
babowc
Car: 240sx
meh.. i dont know, because i am anoob, but that pic is funny lol.. thanks george
Chezedik
Car: 1991 Nissan 240sx
Nistech is probably onto something. I think you are just being paranoid. You see a fuel gauge is just a glorified ohmmeter. The thing you will notice if you have an analog ohmmeter, you will see that the scale is not proportionate. Nor is the one on your gas gauge. So either the top part of the tank or the bottom part will read disproportiately, usually the top. Check what you get on a full tank:MPG = ([Am of Gas Filled - Capacity of tank]/Mi traveled)
If you are still worried after that, then let us know. Plus yes, a lot of people are siphoning fuel, sad but true, buy a locking cap.
ricebike
2002 Quest
2005 Altima
i dont think u can siphon off from a 240sx;unless the fuel filler door is broken, u can't get to the fuel cap.
just do a mpg calculation on next 2 fillups and verify...
JXN
hey thnx guys for helping out, i just filled up 2 days ago and verified that everything is norm.
got about 24 mpg on that run. wheater its leakin or not, that is my normal mpg.
ricebike
2002 Quest
2005 Altima
really, I do appreciate when someone follows up w/ their experiences... so I can learn something new.
DAEDALUS
Car: 1990 Infiniti Q45
ricebike wrote:really, I do appreciate when someone follows up w/ their experiences... so I can learn something new.
