Larz wrote:Ed is right. I always believed that cruise control would electronically keep track of speed and supply fuel at the least possible amount to maintain that speed. Well, if it does work that way, then my right foot beats the crap out of my car's computer. Om my 07 M, the cruise control stopped working and before I could get it in to the dealer, I had to drive up to Tallahassee to referee a rugby match.
Cruise control is designed to maintain speed, not worry about fuel economy. That having been said, I think standard cruise control will most definitely get better mileage than your foot on flat roads. However, I suspect you were using intelligent cruise control, which is going to brake and speed up more aggressively than an intelligent driver would need to (for vehicles in front of you and around curves). Moreover, even if you were using standard cruise control, it will still accelerate more aggressively than an intelligent driver may need to when it encounters a hill, and the downhill behavior of my 2006 M with either cruise control mode is just sad, so it doesn't surprise me that some people could get better mileage with their foot. Personally, I use standard cruise control when driving on curvy/hilly roads, using my foot on the accelerator to prepare for a hill climb so as to prevent the aggressive behavior. I only use intelligent cruise control on 4+ lane highways, using my foot on the accelerator to prevent ICC braking when approaching a car in front of me. Finally, I take varying measures (depending on the hill) to avoid the downhill behavior I experience with both standard and intelligent cruise.
Larz wrote:Don't coast to a red light
I think you should elaborate here. If you keep your foot on the accelerator right until you have to stop, you will most certainly be using more fuel. Additionally, if you were to start braking early and brake the whole way, I should imagine you would be wearing your brakes more while not saving any additional fuel vs coasting (while wind, engine, and transmission drag, which don't require additional fuel, would save your brakes some work).
Larz wrote:keep the foot on the break and don't switch to neutral at long lights - less fuel is burned IN gear than OUT of gear.
I'd love to know where you got this information, and I'm wondering if it might have applied to carbureted vehicles vs fuel injected ones. When the brake is engaged and the transmission is in Drive, I would expect the transmission to have more moving parts and thusly more resistance. Moreover, when I put my 2006 M in Neutral, the RPMs drop vs holding my foot on the brake in Drive. This could imply that less fuel is being used, but wouldn't if neutral actually provided more resistance. However, it certainly feels like the engine is under less load when in neutral as well. I haven't verified this using the OBD2 port, but could if I had reason to believe that piece of advice had any sort of sound backing.
Larz wrote:OR ........
Do what I do:
screw all that, just resign yourself that these are not fuel miser cars, do what you can and limit your spirited driving to sometimes instead of all the time.
OP and other readers looking to increase economy: maybe it's too late for this vehicle, but seriously, look at the window sticker, look at fueleconomy.gov, look at the specifications, and don't by a vehicle that desires or requires higher-than-87 octane fuel if you can't reasonably anticipate being able to afford the fuel for as long as you may drive the vehicle. Taking action to get better mileage in whatever you drive isn't a terrible thing and can be a fun challenge, but being disappointed by a vehicle that consumes fuel pretty much like you should have expected it to is a waste of energy. That having been said, I'm sure there are plenty of sites that have all sorts of suggestions (some more common knowledge than others) on methods to save fuel, so search for them, but when you do, I highly recommend staying away from little gadgets that will allegedly pay for themselves. For instance:
http://www.wisegeek.com/what-is-the-turbonator.htm
