fuel and spark, but no eargasim.
FatJosh05
Car: 91' 240sx fastback
91' 240sx sr20det
hey guys, hoping you can give me an idea of what im over looking...
where to start? so we turned the car over for its first time, started immediately and ran beautifully. shut the car off after its first 30second test fire/ run, and when we tryed starting it a second time no longer than a minute later, it just sat and cranked. i have spark to all plugs, the injectors all split plenty of fuel. i went over all the grounds, went over fuses, unplugged and replugged the ecu. any ideas on why it wont turn over?
i was thinking it could be a bad cas?
i have a jim wolf tuned ecu, tomei 740cc injectors, new nismo fuel regulator, spit fire coils...
sorry for my indecisiveness, long day, frustrated and tired...
any ideas/ suggestions/ help would be GREATLY appreciated!
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Check for codes. Im guessing cas.
FatJosh05
cant check for codes, gauge cluster isnt hooked up...
compactfean
daily
What year SR? S13 is checked at the ecu. You can rather test every single component or finish the rest of the install and get your codes and trouble shoot what is wrong.
FatJosh05
my bad, thought it was checked with the check engine light... and my swap is finished mostly :) but after talking with the guys, were pretty sure its either the cas or ignition timing. well find out tomorrow...
