KASilvia90 »
https://forums.nicoclub.com/kasilvia90-u28447.html
Fri Jan 12, 2007 9:30 am
I copied it from another site I posted it on. I started a new thread since I know the exact problems now and need to know how to fix them.
Okay,I had a long talk with my car and mystery car problem is slowly revealing itself.
The ECU finally decided to give me the code I was looking for, 21: No ignition reference pulse.
If I understand the way an ignition controls unit works correctly, the voltage passes "through" the coil (positive to negative terminals). Then when it is its time to fire, that circuit is broken and it fires to the distributor... But where is the signal cut? Is it cut on the negative or positive side and what component actually does this? I was looking on the wiring diagrams and both + and - wires go straight to the Power Transistor unit. Could that unit have gone bad? I have continuity through basically everything so whatever actually breaks the circuit to cause spark has to be what is wrong, it just has to.
Another noted issue which makes no f'ing sense to me, I pulled the distributor out to check for spark/fuel timing relationship by unhooking all injector harnesses except one and spinning rotor and noting when it clicks in comparison to the rotors location. Well Cylinders #3 and #4 spray on the intake stroke but cylinder #1 sprays on on the exhaust stroke and cylinder #2 sprays on the power stroke. My car at idle always had a very calm hesitant miss but nothing problematic, I assume that issue would cause drastic idling problems... Basically getting signals #1/#2 are backwards would always have been, the harness isnt crossed.
Anyone have some help they could offer, I'd really like to leave the house sometime this year to go see my girlfriend.
