I have an R33 Rb26 with CP pistons, eagle rods, ACL race bearings all around, yellow jacket coils, Tomei adj cam gears, gt35 (thinking of going gt45), N1 oil + water pump.
those are the main modifications done so far to the motor. Still running my break in tune due to lack on money to upgrade fuel system (which will be ending shortly after lawyers finish with all their legal stuff)
Ill be looking at upgrading the fuel system completely. What would you recommend for the gt45 to max it on pump fuel (only got 91 octane here
as well, I'll be needing some work done in the head for springs and cams.
I have Brian Crower SS Valves (std size), Tomei adj cam gears. Everything else is OEM.
What would you suggest for springs + cams and any other mods needed.
This is just a mock list of things i did with a VERY FAST search.... does this sound good or should I change anything?
Tomei Phosphor Bronze Valve Guide Set
Tomei Poncam Type-R Intake and Exhaust Camshaft - Not 100% sure on these or which springs to go along with them
AEM High Flow In-Tank Universal EFI Fuel Pump
Greddy/Tomei/RawBrokerage 11.0mm Fuel Delivery Tube
Grams Performance 1000cc Fuel Injector Kit Top Feed 11mm
Im assuming the stock fuel lines will be constrictive. Would anyone like to share input on feed/return lines for fuel?
I know this is a big/broad question. ill be looking for ~650hp daily conservative tune and whatever numbers I can get above that on track days.
Thanks for the input guys. Mucho <3
