Fuek filler door is stuck
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
jwestdorp
any advice on opening?
I have a Inifiniti G35 coupe 2003
Q451990
Honestly, I don't... a copy of the FSM my give you an idea. Does it have an electronic opener... if so do you hear it click?
If you have warranty left - I would let the dealership figure it out - and stress that you don't want to have anything repainted!
Heath
5zigen
I had this same problem on my Q...
It just makes a clicking noise and won't open. Needed a screw driver to pry it open while having someone else press the button at the same tiem and eventually the problem went away by itself.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
when i had my g [sedan] i noticed that there was no release handle. i would have to unlock all the doors in oreder to get the fuel door to open [and then it would just push open]. if that's not your problem, than like heath said, use your remaining warranty. i know you have at least 9 monts left unless you've already got 60k.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
im going to move this to the G35 forum and see if you get some better responses there.
szh
Car: 2018 Tesla Model 3.
I think that in the 2003 model year (others too maybe), the opening of the fuel door was kind of unusual. There was no button ... you simply had to "unlock" the car with the fob (even if the car was unlocked), and then push on the fuel door on the "opposite side" of the door. If you locked the car, the fuel door then "locked" too.
It was confusing ... I had a loaner one time and had to call the dealer to find out how to put fuel in! Embarassing.
Could this be the situation here?
Z
SCOOTER240
Car: 1990 240sx sr20 black top
there is a manual release located on the lock mechanism itself-you need to remove part of the trunk liner on the passenger side-just enough to get your arm in ther to reach it-there is a small white knob type thingy that you can pull on to release the lock-i've seen this alot-if it is still under warranty just take it to the dealer and have the gas door actuator replaced
JDMEnthused
Car: Nissan 240SX
wow.. ive never really heard about this on Infiniti's its becoming ever more common on S13's and 14's though..
Return to “G35 and G37 Interior, Exterior and Audio”
