ft/lb Torqe
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
1mean16vSe-r
Car: 200SX SE-r
I drive a '98 200Sx SR powered. I have plenty of top end power and i am trying to widen the power band and get some low end as well. Any suggestions on wat i can do to increase torque without forced induction, i want to keep my motor N/A- im old school i guess haha...
nametakennow
Car: '06 MINI Cooper S
There's really not much outside of boring it out that will give you much increase in low-end power.
What mods do you have now?
Nismo77
Car: 72 S30
The only way to increase torque on a N/A is to stroke it...other than that an engine will only put out what it was designed to do according to the rod ratio... you could have a custom header made that could help with th low end but that will cost you some money..
1mean16vSe-r
Car: 200SX SE-r
How much would it cost me to boar my engine
nametakennow
The JWT stroker kit (which is the only one I've seen) runs ~$2k, and the labor would be very intensive. I suspect the whole shibang would be $3kish
JeremyNissan
Car: 99 SEL SR20VE-T
advance the timing and get a lightweight flywheel with underdrive pulleys. That will free up around 15lb ft on the low end.
I think a good tune will give the best results. But that will get you started and you will feel the diff right away.
Q45tech
Torque is a function of displacement and compression ratio. BMEP and it's negative IMEP or frictional loss create the net torque output.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
