sultan »
https://forums.nicoclub.com/sultan-u295.html
Thu Jul 08, 2004 7:19 pm
am i the only one that doesn't like the stillen bar? the bar itself is nice and beefy, but it's only adjustable on one side. that would be fine except for the fact that the bar is marginally long enough. the "stillen" doesn't sit in the center, and there's only 2 threads engaged on the adjustable side. to get that much i had to pull on the bar as hard as i could get the bolt in.
stillen obviously made a universal bar that would fit several cars using different feet. if both ends were adjustable or if the one was longer it would be ok, but why isn't the freakin bar longer?
i have three cusco stbs (2 front, 1 rear) for my S13, they don't have adjustable heim joint ends, they're made to fit the car. the bolts mounting the bar to the feet are slightly smaller than the holes, so there is only about 1/4" of adjustment. am i concerned they won't fit? nope, they're actually made to fit the car!
greg, if no one else wants to take over the project i will. i have the stillen feet, i can just get them copied or modified to work.
