FSM
1996QShip
Car: 1996 q45 pearl white with 66k
Could somebody lease shoot me a copy of the HA portion of the 92 FSM? I can't seem to access my copy. Apparently my external hard drive is on strike!
Thank you in advance for your help.
OwnerCS
I'm not able to email from my location here, but a link to the FSMs is in my signature below so it can be downloaded again..
1996QShip
Thanks. But I was hoping for first gen G50. The buttons are different in the 94+
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Yes they are. You need to read the previous posts to learn these differences.
Q451990
As far as I know, there are no online/pdf copies prior to the 1994 model year.
Heath
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q451990 wrote:As far as I know, there are no online/pdf copies prior to the 1994 model year.
Heath
And never were.
1996QShip
Thanks guys. And you're right. I was able to run diagnostics on my 92 through the climate control. I received a code 41. A few months ago I tried to clean my evaporater because my drain hose was clogged and water built up inside. However when I reassembled everything back. I didn't replace the screws back properly. There's a screw that's made of a different material and I may have placed it in the wrong spot. Whereby causing a short. So I'm gonna try to fix it today. If somebody has a picture of their dashboard after the glovebox is removed would be extremely helpful to me
Thank you in advance. You guys are great!
1996QShip
So I kinda got my ac running for about 10 mins. I've been suspecting mu ac relay to be faulty. So earlier today I exchanged the ac and the cruise control relays to test it. My ac worked for about 5 mins. then I blew the cabin ac fuse. I then drove the car to check if the cc was working. And it was. But the cc light did not come on in the dashboard. So I'm wondering if the two relays are the same or not. I know they have different part numbers. But I wonder if they're the same functioning capacity?
